Configure the Guest VLAN ID
Use this procedure to configure the Guest VLAN ID.
Configure the Guest VLAN ID.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol guest-vlan 10
The following table defines parameters for the eapol guest-vlan command.
Variable |
Value |
<1-4059> |
